Jun 26, 2015 #22 V v6turbo87 Active Member Joined Mar 27, 2014 Messages 546 Your O2 cross counts are all 0. Looks like your O2 sensor is dead. Replace it and it will probably take care of the lean condition. Last edited: Jun 26, 2015
Jun 26, 2015 #23 V v6turbo87 Active Member Joined Mar 27, 2014 Messages 546 TPS voltage is low too bring it up to 0.42-0.44
Jun 26, 2015 #24 L l3lue Member Joined Jun 19, 2005 Messages 216 v6turbo87 said: Your O2 cross counts are all 0. Looks like your O2 sensor is dead. Click to expand... I have a new one on order
Jun 26, 2015 #25 John Larkin Sublime Master of Turbology Joined May 25, 2001 Messages 5,013 You can buy one at Autozone in stock for $20, Bosch 12014 plug and play.
Jun 26, 2015 #26 V v6turbo87 Active Member Joined Mar 27, 2014 Messages 546 P.S. spark plug wires read on average 3000 ohms per foot, not 0 ohms.
Jun 26, 2015 #27 W whitehot1 Well-Known Member Joined Oct 24, 2006 Messages 4,682 What plug wires did you get? Autozone Bosch premium plug wires work great and are less than $30.00 and an added plus come with a lifetime warranty.
Jun 27, 2015 #28 L l3lue Member Joined Jun 19, 2005 Messages 216 Disconnect and reconnected O2 sensor since new one hasn't came, replaced PCV valve and adjusted TPS and took car out for a drive, how does this look? BLM at idle are still at 150 though, from what I see vacuum lines are ok Attachments 2015-06-27_17.08.28.pdf 2015-06-27_17.08.28.pdf 254.1 KB · Views: 25
Jun 27, 2015 #29 L l3lue Member Joined Jun 19, 2005 Messages 216 Took for longer drive and got gas , is it just me or do these numbers look better? Attachments NEWEST 6.28PM 6-27.pdf NEWEST 6.28PM 6-27.pdf 289.2 KB · Views: 41
Jun 28, 2015 #30 L l3lue Member Joined Jun 19, 2005 Messages 216 anyone have any input? or point me in the right direction to make sense of the numbers and what they mean ?
Jun 28, 2015 #31 Pronto No amount of evidence will ever persuade an idiot. Joined Dec 9, 2002 Messages 16,811 http://www.vortexbuicks-etc.com/Scantool_Readings.htm This will give you lots of info on you scantool numbers.
