Okay, Im making more power than ever running straight methanol. I am having zero to no more than 2 degrees of KR at the topend with 23 psi boost. O2s throughout the run are anywhere from 824 to 860. If I could lean that out some I could really get moving. Only problem is I am having problems at the beginning of the run. 26 degrees of KR at 13 mph with 5 psi boost and 832 O2s. I have to let off the pedal because of the obnoxious audible KR sensor going crazy. This is rediculous, I used to just tune for no KR at the topend (higher mph). Now Im there, really making some power, but I have to get off the pedal because of KR at low mph
Can this have anything to do with the Methanol Im injecting? I never had O2s that high before with this type of boost, until using straight methanol. Is it possible to get KR from running too rich?
Need suggestions on how to proceed..........please.
Thanks guys/gals.
Thanks guys/gals.
