ITS RUNNING! 2 2/1 years later w/pix
The hoses were sold by Postons, out of production for several years, I have a set on my 87, much deeper blue and slicker than the hi-miler goodyear hoses, but definitely low production tooling.
:cool:
Complete Motor FOR SALE!!!
Complete stage II/stage II Enging FOR SALE w/Big Stuff 3 w/Stand Alone harness
The best of everything.......
274c.i. Buick On-Center Stage II Block (4 Bolt Main Caps)
4.020 Bore
Weisco Pistons w/ Tool Steel Rings
3.625 BMS Crank
Carrallo 6.5 Rods
Comp Solid Roller Cam
T/A Timing Chain
Solid Roller Lifters
Billit Cam Gear
Composit Cam Sensor Drive Gear
BHJ Harmonic Balancer
JW Flexplate
Duttweiler Oil Pump
Fittings & Hoses for Oil System
Deepend Oil Pan
H.V. Front Timing Cover
Water Pump
Buick Stage II Heads w/Crane Rockers / Flows over 340
ARP Head Studs
Cometic Head Gaskets
Solid Motor Mounts
Under Drive Pulley
Edelbrock Tunnel Ram Intake
Custom Buick C-N-C Intake Cover
Converted Intake to Fuel Injection
Stock Linkage works with Intake
Cometic Intake Gasket
75mm Throttle body
Limit Eng 76 Turbo
PTE Front Mount Intercooler w/powdercoated Pipes
C.P.P. Stage II Headers
Custom Downpipe
Tial 46 mm Wastegate
Copper Header gaskets
160 lbs Inj
Aero-Motive Fuel Pressure Reg.
Billit Fuel Rails
Coil Pack & Module
MSD Plug Wires
Accel Fiberglass Boots
200 Amp Alt
All Sensors come with package
Oil filtration System w/-10 Oil lines
Inline EARLS Oil Filter (before oil pump)
Comes with EVERYTHING under the hood
Engine has 1000 Street miles on it (never had it to the track)
Over $26,000 invested in PowerPlant & Fuel Mangement
$16,500 gets EVERYTHING
Please e-mail me at BAGN231@yahoo.com
Thx,
Chris Conley
Hey Chris,
You gonna actually drive that beauty. Needs to be put under a glass dome and admired by the masses.
Just plain beautiful :cool:
George, in ALBERTA
damn if someone had a TSO roller, they could throw an 88 on that thing & go TSO racing by BG.
