Just got back from the track (stock setup)
Nocooler
Had a Hotair
It was a good day @ the track today - 45 degrees and sunny.
I was running a Thrasher 108 and 20psi w/pump gas and alky.
1st pass:
60 - 1.811
330 - 5.146
1/8 - 7.962 @ 88.5
1000 - 10.391
1/4 - 12.448 @ 109.06
2nd pass:
60 - 1.772
330 - 5.056
1/8 - 7.853 @ 88.1
1000 - 10.263
1/4 - 12.306 @ 109.51
3rd pass: Up in smoke
Run 1 and 2 I left on "0" vacuum. Run 3 I tried 1 psi but didn't get any heat the the passenger side tire (peg leg). BTW - tires are 275/50 BFG DR's.
I'm thinking my next mod will be a Eaton posi - I want to leave on boost.
The gasket at the cowl is there - and I don't have an extension on the IC scoop.......I'll have to try those.
The turbo is stock.
Jeremy
