Car should be making over 300hp to the wheels. Id fix all the problems with the car first. The VSS code 24 and the CTS error 1 at 17psi5 are causing big problems. The chip needs to know the wheel speed or it will think its in first gear or default to a different setting. If the ecm sees low coolant temp it will add fuel in open and closed loop and may default to a setting when airflow is maxed on the MAFS. Id make sure your manually locking the torque converter before the dyno pull. The numbers will come up a lot.
1. Fix error code problems.
2. Make sure sensors are adjusted correctly, especially the TPS.
3 Make sure the fuel pump is getting alternator voltage and hotwire if necessary.
4. Get some better fuel in the car. The more octane the better.
5. Using the TT chiop get tyhe car to run around 11.0:1.
6. You can slowly add boost and timing while adding fuel on the chip.
7. Car should put down over 400 hp and 600 ft lbs with the converter locked, 25 psi, and 24 degrees advance. Id tune to 11.3:1 for max power on a wideband readout.
