Originally posted by Ormand
Changing the rear roll stiffness, with heavier springs or a heavier sway bar, will shift weight transfer from the front to the rear. In extreme circumstances, with one end much stiffer than the other, you can lift an inside wheel during very hard cornering. Old racing Ford Lotus Cortinas lifted the inside front, lots of stiffened front wheel drive cars will lift the inside rear. There is a possibility of getting oversteer, if you make the rear too stiff relative to the front. Even with stiff rear springs, and a "soft" sway bar, it is possible to unload the inside rear wheel to the point of losing traction. Think about it. If you corner at 1 G (it makes the numbers easy, even if it ain't realistic) you will shift weight from the inside wheels to the outside wheels. The amount of weight is determined by the track and the height of the center of gravity. The only thing the suspension settings can change is the distribution of the weight shift, front to rear. Example- you may shift 1000 pounds from inside wheels to outside wheels. If you make the rear too stiff, and try to resist the roll with rear axle only, you don't have 1000 pounds on each rear wheel, so the inside wheel would would either lift, or become unloaded, which is the same thing, it just isn't as obvious. For drag racing, none of the above matters (much).
George W
Raleigh, NC
