Just installed DFI!
BigChinooks
Having problems-->>Car starts,rpms climb to 2200rpm and slowly come down to 1000 rpm and shuts off.
Everything ran fine before install and i will not have a laptop untill tomorrow.
Any ideas?
Wait until you have the laptop tomorrow.
Which version DFI is it?
The current DFI Gen 7+?
All will go smooth & quick for you tomorrow,
with the laptop. :)
It is older DFI gn 6.
I got it running,but when i put it in drive it stalls........i will figure it out!
I need a good source for an EGT gauge,anyone know of one?
Mike.
I would guess that the IAC is set to open way up on startup, and as it closes once the vehicle fires, you get into an area of the map that doesn't have enough fuel to keep the engine running properly. Richen the idle area and see if it stays running.
