Da--! Put on a new Cat, turned the TPS down to .34, put in the GAURANTEED TO PASS juice, one pint of methyl ethyl achol, got it fire engine hot, and FAILED badly!! What the He--? How do you guys do it here in sunny CA? Any suggesstions would be greatly appreciated!! Ron
Here's the specs:
1987 GN
TE-44C trbo
NEW injectors: 42# (009's)
Adj regulator: fp set to 40# (as low as it will adjust)
3 Bar MAP
Stck MAF
Stck exhst, w/New CAT
Stck eng, hds, etc
TPS adjstd dwn to .34v
Scan master (reading 750-800 at idle)
Cold Air intake:
Here's the specs:
1987 GN
TE-44C trbo
3 Bar MAP
Stck MAF
Stck eng, hds, etc
Cold Air intake:
