Little6pack
- Jun 2, 2002
Garage went from 39 to 67 degrees in 6 mins
SignUp Now!Originally posted by littlesixsteve
Garage went from 39 to 67 degrees in 6 mins![]()
My unit is Reddy heat torpedo 30k btu brand from Home Cheapo.
You really can't use it in enclosed area without venting.
I will run it 10 mins tops without cracking the garage door open.
If I have to run it longer then the door must open 1 inch to vent.
The temp does settle back down to 47/50 range after an hour.
Originally posted by Red Regal T
Don't need a heater.![]()
Originally posted by KLHAMMETT
House temp is 70, Garage maintains a florida like 80 just because the boiler is in there.
Otto
