the ac delco filters for these cars has a anti drain back valve so the turbo gets oil on startup, other companys dont. if you have the oil cooler on the vehicle you need the pf47, if you don't you need the pf 52. their might be a clearance issue if you put the 52 on with the cooler adapter, usually not.
