...so k1 rods call for .008 to .012 side clearance from the rod to thrust side of crank...im only getting about .006...i have only done my first retorque on the rods of 30 ft. lbs. plus 60 degrees on the torque angle gauge...is this going to be a problem...do i have to send it back to the machine shop for them to adjust the crank?...im going to loosen the rod bolts three or four times and retorque and hopefully the rods will center on the pins of the diamond pistons other than that any suggestions on what is ok for rod side clearance?...thanks for help...noah.
