Avoid a HV pump with the TA pump cover (or similar) The last StageII I did with the TA HV oil pump cover (with external lines) it would PEG a 125psi oil gauge at idle. It would FILL the passenger side valve cover with oil with in 10 seconds of run time (temporarily used a -8AN bypass hose the the passenger side vavlecover to verify that the by-pass system was even working. Yep, it was. Also BLEW up an oil filter O-ring, too.) Absolutley no need to run HV oil pump on a stageII. We are running .002" bearing clearance and bushed lifter bores w/ .060" oil feeds. and radius all oil passages. THis was using a stock 4.1 timing cover with radiused passages, and the pump boss trued on a mill so the gears sit parrallel with the face. Milled .125" off the face to align the cam/cam sensor/dist. drive gears. The TA pump cover sure improves the oil circuit in these Buick V6's.
