deezdad
- Mar 25, 2005
I realize neither are ideal but is the kb set up at least an improvement over stock? How bout sound/noise, any diff between the two? Thanks ..
SignUp Now!This is exactly how mine is set up too.... removed the canister and have the hose going to the filter.
Would it be possible to see a picture of your set-up? I've got the same canister also. It would be helpful to me, if it wouldn't be too much trouble......I've been thinking of cutting the bottom of the canister out like another member here did...it gives the appearance of a canister, but the bottom is open to get fresh air.....am considering all of these possibilities as I know the Kenne Bell Ram Aid system is restrictive.....thanks.It's restrictive. I ran a 14" filter so some of the filter could breath, and now just removed the canister and have the hose going to the filter.
Bruce '87 Grand National
Did you ever modify the canister Bruce? I finally got one and cut out the end with a 4.5" hole saw, then used a half round file to till I got to the edges. Figure now it won't starve for air when taking off n then gets outside air when moving.Would it be possible to see a picture of your set-up? I've got the same canister also. It would be helpful to me, if it wouldn't be too much trouble......I've been thinking of cutting the bottom of the canister out like another member here did...it gives the appearance of a canister, but the bottom is open to get fresh air.....am considering all of these possibilities as I know the Kenne Bell Ram Aid system is restrictive.....thanks.
Did you ever modify the canister Bruce? I finally got one and cut out the end with a 4.5" hole saw, then used a half round file to till I got to the edges. Figure now it won't starve for air when taking off n then gets outside air when moving.View attachment 297978
The cut end is the end that faces the drivers side fender, the hose from the air dam scoop still connects to the angled part you see in the pic, install is exactly the same as original just is open at the end now so it gets air at low speed. Steve V. down in Va.( who I highly recommend if you need help with your car) is putting my car together for me at the moment, when I get it back this spring I'll be glad to get you a pic.. Hope you get through your bad time ok.
