Hey, Brandon.
The hose is 4 1/2" -5" & yes, "squish it"
Then use a BIG zip-tie or a hose clamp to secure
I'm also going to play with this:
I found this at Home Depot its an
"Extend-A-Spout" #81015 ($12.45)
(I scored a K/B dual intake from a board member & want to use both sides)
The spout fits the intake & can be cut to length, I'm thinking that I can conform it to the intake w/ a heat gun
& come w/ 50" flex hose.
My cone filter is currently in the engine bay, but I'm going to relocate back to behind the headlight; I used a rubber 90*
elbow from H/D plumbing section, (might try the hard plastic this time for weight savings)
& put it through the headlight hole; the end secures it.
I switched my cone filter to a Spectre a while back, it is "open" on the end & they sell a little plastic adapter to
pug the hose onto.
So I'm hoping to feed some "cold" air to the intake & rig the P/S to run some air into the turbo/ down-pipe area to aid in cooling
D
