Sal Lubrano
- Apr 26, 2002
I am posting here because it is not for a GN. My friend wanted a started kill in his 87 Monte so we cut the starter wire under the dash and ran both ends of the wire to a hidden switch. Worked great for a while. No crack until the button was pushed. Then one day it did not want to crank so we bypassed the switch and then it worked. Figured maybe too much amperage and fried the switch. So, we got a new switch and this time I installed a N.O. relay which when energized from the hidden button will close the contact. Again worked for a week and then the car would not crank. Put the starter wire back together and the car started? Here is where it gets really confusing. In both cases with the relay and without it was like pot luck sometimes it would start and others it would not. But as soon as you put the starter wire back together it would work flawlessly for weeks without a problem. We used 14awg wire. Anyone have any thoughts as to why this is happening?
