I just put new battery into the lead graveyard today...fried another cell in that ultra 800 O'riely special.
I just got this new replacement battery at under warranty last week and it already has a dead cell after four days. I suspected the first battery went dead due to a failing fan delay relay, so I replaced the delay relay on the driver's side fender. I was sure the relay failed and killed the first battery, since the fan seemed to flicker off and on when the old battery was near flat lined voltage. Well, after I replaced the relay, I just hooked the new battery up without checking for any shorts. Low and behold a few days later the battery is dead.....
I guess I will just get another battery and test for shorts during installation? Then pull fuses if required to find the short.
1.) Do you think they will give me another one under warranty since I just got one last week?
2.) Could the fan delay fan be falsely tripped on by a bad sensor? What else would cause the relay to activate??
The alternator is fine because when I jump the car, it will drive around until it is turned off.
Thanks for the help!
