Jackie grabos
- Feb 2, 2011
i have just installed caspers audible knock gauge. i also installed manual boost controller. when i took it to test was getting boost to about 12 psi and getting 1/2 second knock alert. i have boost controller screwed about 2 1/2 turns in. how am i getting knock when the stock setup is for 14.7lbs of boost? shouldn't i be able to get 15lbs without knock at least? i have a vacuum boost autolite combo gauge. the turo is bigger so it does not spool up as fast and i have exhaust leaks. running hooker headers now but having stock manifold put back on. i have older extender chip in. if i switch back to stock would that help? i would like tt chip but not sure of turbo. i think it is 70mm and injectors are lucas red stripe and 41.8lbs/hr. do not have scanmaster yet and know i need to get one. any help appreciated. thanks
