The gen 6 dfi will retard the timing and you can view that on the screen, but i would still get a knock gauge, because by the time the dfi responds to knock its usually too late! The fuel pressure should be set at 43 lbs and you adjust to your program to work with that pressure, you should not be adjusting it like you when you play with chips!
