SignUp Now!Mid 600 To 700
30 Mph
Judging by what you have listed in your first post:340 HOTWIRED FUEL PUMP
42LBS INJECTORS
110 OCT FUEL
STOCK TURBO
FUEL PRESS REG SET AT 45LBS
7 TO 10 DEG ON SCANMASTER
STOCK CHIP
15LBS OF BOOST
TEMP 175
You still mentioned STOCK CHIP & Blue Top injectors. If you run a stock chip you need to run stock injectors!i was thinking of my other gn has the 42s
this one has the blue tops, stock chip, fuel press is at 42 with vac off
boosst set at 15 around 10lbs it starts to show 6 deg of kr
new fuel pump was put in in july from full throttle with new filter and billit fpr
