Matt Weiser
It's an F.U.V.
- Dec 17, 2001
Seems like I read in a recent thread that too much fuel can cause knock. True?
Reason I ask is I'm fighting a battle with part-throttle knock. I'm showing double-digit knock retard at low boost and recently installed a Power Plate to try to deal with it. This helped, but it seemed to just move the problem higher into power band. Now I'm getting over 10 degrees KR at around 8-10 psi. (I also reset IAC and TPS after installing PP.) My O2 readings during all this seem high, between 820-850.
This is on 91 octane California gas (best I can get) with max boost set around 15 psi (though I never see that because I back off with the early knock). I have a stock fuel pressure regulator, 30lb. Tomco green stripe injectors, a hotwired Walbro 307 and a new timing chain. I already did the Top Engine Cleaner. I also know it's not false knock because I can hear it. I have not verified if the fpr is working right (it's original). I do have a 237 regulator I could install, but wouldn't this just make the 02s even richer?
So, could it be TOO MUCH fuel? What else can I do?
