Sep 20, 2007 #1 3 325DR New Member Joined May 30, 2001 Messages 660 Do all of you guys run the factory knock sensor in your 9 sec or faster cars?
Sep 21, 2007 #3 I III'S 87 GN Active Member Joined May 19, 2002 Messages 869 RICHIE HIGH PSI said: yes Click to expand... He said NINES !
Sep 27, 2007 #4 3 325DR New Member Joined May 30, 2001 Messages 660 Any of you 9/8 sec guys NOT run a knock sensor? I find it hard to believe that the very fast cars run knock sensors. Especially those with solid roller motors which add valvetrain noise. Can any more of you comment?
Sep 27, 2007 #5 K KevinB Well-Known Member Joined Dec 2, 2004 Messages 6,438 I do not. But I do log every run to moniter the wbo2 and I also pull at least one plug every run to check for any detonation.
Sep 30, 2007 #6 Q quickt Well-Known Member Joined May 25, 2001 Messages 1,918 RICHIE HIGH PSI said: yes Click to expand... with your new stick and you wont be using much longer
