Knock Sensor interchangability?
karolko
Does anyone know if all GM knock sensors are infact the same? I have seen some that look identical on votrec 4.3l, 5.7l and most other GM motors.
I am looking for a new one, but they seen to be super expensive.
Adrian
I remember doing some cross referancing. I ended up using a LT1 knock sensor.
A quote from an article on the TT website.
"The sensor in the turbo 3.8L has a resonant frequency of 6 KHz. "
That is good to know, but no parts guy will be able to tell me what is what. Or will they?
Does anyone have a new knock sensor for sale?
GM PART # 10456287
ACDELCO Part # 213325
You should be able to find it for $35-$45...
And it does appear to have more applications than just the LC2, icluding the LT1 as DD wrote about and maybe the TPI and possible the LS series.(it's just listing a year range from 85-2002)
You know...it's function is critical and certainly not worth saving $10 here or there. Piece of mind sometimes isn't cheap....
Thank you WS6. I will look the part up when i am home once more. Thanks again.
Adrian
