- May 23, 2001
The XFI seems to not be picking up any knock (ESC Retard). Even when you do the socket extension "tapping test". Replaced the knock sensor with a brand new Delco unit. Installed the knock sensor at 13ft lbs and with the car off but key on and logging I tapped the back of the block, intake, side of the block, and valve cover. I would not think the wiring in the XFI adapter (Casper box) harness is crossed. I dont really want to turn up the boost until I know for sure that knock can be read.
Rob Hinson
Rob Hinson
