BRAD_PADGETT
- Jan 22, 2004
Does anybody know any steps which make changing out the knock sensor easier? I am replacing my knock sensor and need to get the right torque. Thanks- Brad
SignUp Now!brad, souns like you are having the same problem i did. good luck. i never figured mine out
very true. i was getting so pissed off, i went to and XFI and it fixed it some how.
Thanks- I am going to remove my fxxxing knock sensor and personally beat the sxxt out of it with a sledge hammer. I am sick and tired of replacing everything and guessing on WTF is going on.
One of the last things on my knock problem list(Suicide Six-Knock Knock Boom) is the knock sensor. Powerlogger confirms that knock starts at three lbs boost no matter what. The stinking knock sensor must be picking up the sound of the turbocharger. Ta33C and stock turbo both cause this. Alky, timing, ESC, HR motor mounts, fueling IGN.. blah blah changes have not made one difference in my knock problem.
Venting frustration here. Here is my plan. If the new knock sensor does not cure the problem then the ECM and chip will have a date with sister sledge and be replaced. If a new chip and ECM won't fix the knock problem then the waste gate actuator rod will be disconnected. I will have then achieved one really great looking GN with capable of an 18 second quarter. Thanks- I will keep everyone posted and throw any and all comments out here. Nobody can hurt my feeling here! Brad
