Knock wth
bttwracing86T
YOU CAN'T HANDLE THE 6!
OK so I noticed this I have transmission out but made a few changes to motor like egr delete new hoses new oil pressure gauge fired it up all seemsnok the give it some revs and I get knock any ideas will this do that because no transmission ?
Is the engine supported or is just hangingon the motor mts? loose bolts on flexplate, trans oil lines hitting starter/exhaust? Starter shield loose? Engine touching the firewall? Shift linkage rattling against frame?Some ideas for faulse knock.
Engine just on motor mounts I'll check flywheel bolts to make sure maybe hitting firewall. Thanks for advise I shouldn't worry its probably just something because the motors at a different angle with transmission out.
Sent from my XT907 using TurboBuick Mobile mobile app
