Knock
MauDeuce50
Need Rehab for Boost Addiction
Hey guys, My scanmaster is reading a few degrees of knock at around 50 mph... The car has 126000 miles on it... Rod knock?
If you are cruising at 50 and have kr its likely picking up vibration from something. Downpipe hitting anything? Motor and trans mounts ok?
currently cutting it the F loose
Check to see if your knock sensor is torqued properly.
Downpipe is less than .5 inch from headers, never really studied it before, is that ok?
