Scanmaster issue
Atompilot
Hey guys, I have an 85 GN. Installed the Scanmaster last week, L8 is the only parameter that works, everything thing else shows 0. Any help would be appreciated.
A
I had to do this as well and when you upgrade you can add a translator and new style maf .your car will thank you.
Thanks, I have the translater already plus a custom chip installed from Bailey engineering for the 1985 GN. Are you still saying that an 86 or 87 ECM is required?
A
When going over to the 86/87 ECM you'll want to install Caspers MAT Kit & Air Temp Sensor (IAT)
MAT Installation Kit:
https://www.casperselectronics.com/cart/index.php?route=product/search&search=107136&description=true
Installation Instructions: https://www.installationinstructions.com/102065.pdf
Not sure of the upgrades you have for your 85 - Nothing in your "Signature" so Caspers has a few products to make life easier on us Hot Air guys / gals.
84/85 CCCI Hotwire Special Uses 87 CCCI MODULE and COIL
https://www.casperselectronics.com/cart/index.php?route=product/search&search=102084&description=true
Installation Instructions: https://www.installationinstructions.com/102084.pdf
