Originally posted by bruce
Sorry I've grown to ignore sig lines any more. Too often just noise.
Anyway the best chip for your L69 is available from GM.
Get the ZZZ retrofit engine manual, in it you'll find the best chip ecm ESC modules etc.
The secondary metering rods are discontinued.
You'll have to source them somewhere else
The 4.1 Buick V6s had a close enough set of rods to work well.
If you want to get the carb right get Doug Roes Q-Jet book, and set up the adjustable secondaries, and develiope a set of the different secondary hangers.
The best Air Filter setup is a Moroso drop base, might have to trim it a little. and then use a 2.25" K+N. No not 3".
The L69 will run better then you imagine when right.
