LARGE PARTS LIST/ Bought another Parts car
Intercooled88s
Moderator
New Parts added to list
84 Hydrobooster brakes $100
87 GN grill $90
87 GN header panel $250
87 GN fenders $100 each
87 GN Front bucket seats need recovering $150
86-87 GN locking T-tops $150 a set
87 Blue lower Concert sound door panels $100 for pair
86-87 AC compressor $60
3 switch panel that fits in ash try,in console, with 3 switches $15
CCCI Adapter harness(harness lets you use 86/87 Ignition module with 84/85,plugs into hot
air harness $25
Misc.
BRF valvebody $200
GN rearend(8.5 non posi , drum to drum withdriveshaft ) $500
Driveshaft for 8.5 rearend $50
Transmission cross member $40
87 GN good running 109 short block $700
BQ coded GN transmission 48k $300
BRF tranny $500
Stock 200 4r tranny pan $30
86-87 GN wheels good for cores all 4 for $120
INTERIOR
Steering column(floor shift) $120
85-87 Gn Steering wheel(good to have recovered) $50
85-87 GN console $140
Plate on console that goes around the shifter $40
84-87 GN shifter $35(needs T handle)
86-87 GN seats $400
86-87 GN lower door panels $60
Grey rear sail panels(panels around the quarter windows) for t-top car in great condition
$40 for both
Grey Third brake light $25
85-87 GN seat belt set(10 pieces) $70
I have all the plastic interior pieces for a marroon or grey car with either t-tops or hard
top .
Nice grey arm rests $15 for both
Nice blue passenger visor with lighted mirror $25
Map light $20
Gauge surround $35
radio surround $25
Stock GN radio $50
Maroon dash pad $110
Blue dash pad $120
Grey dash pad $110
Light sage green arm rests(these are the rare light green color) $40 for both
Light sage green seat belt guides $25 for both
Light sage green seat belt upper bolt cover, triangular shaped trim piece $20 for both
T-TOP trim around the t-tops on the inside of the car in Red, Maroon, or grey , all 6
pieces
$100
ENGINE PARTS:
84-85 valvebody with TPS,IAC motor,vacuum manifold $50
stock 86 chip $30
stock 84 chip $20
86-87 Turbo $150
86-87 Turbo can be used as a core $75
84-87 Turbo elbow $25
86-87 MAF $80
85-85 ECM $40
86-87 ECM $70
Engine frame mounts $35
86-87 oil return to block, brass adapter,screws into block in front $20
86-87 Throttle bracket $35
Intercooler brackets both for $50
underdrive pulleys(crank and alt) $40
86-87 Crank pulley with adapter $30
86-87 dipstickand tube$40
86-87 Factory Oilfiller tube and cap $30
86-87 Scoop for airbreather $20
N/A crank std./std. $40
109 Block $300
crank $325
.020/.020 Turbo crank fresh from the machine shop $150
stock 8445 heads needing rebuild $40 a set
86-87 Lower intake manifold $130
84-85 GN intake $40
84-85 fuel rail $25
Any year injector harness $35
84-85 valve covers $35
86-87 valve covers $35
cam position sensor just the lower part(no cap) $30
86-87 MAF $100
84-85 MAF $45
84-85 AC compressor $40
84-85 Alt $35
84-85 turbo adaptor $25
84-85 crossover pipe $35
84-85 Alt $30
84-85 engine wire harness $100
86-87 engine wire harness $175
Any other harness on the car e mail I have them all
86-87 Power steering pump $60
86-87 AC compressor $70
86-87 Belt tensioner $70
86-87 Alt. $60
86-87 Main accessory Bracket $80
84-85 Main accessory Bracket $50
Small plastic guide that holds the posi bat cable to the lower front cover $20
84/85 to 86/87 conversion parts(all the original GN parts you need to convert over from 85
to 87) $1500
Oil cooler adaptor with nut $35
Timing cover $30
Turbo rods(2 dot) $40 a set of 6
Turbo flex plate $25
Turbo oil pans $35 each
84-85 control module $50
84-85 coil pack $40
Body & Misc.
mast for manual antenna $30
PowerMaster brakes assembly $200
Vacuum brake assembly +pedal $65
GN Front bumper $130
GN rear bumper $100
Alum. rear bumper reinforcement $80
86 GN grill $90
85 GN grill $60
85-87 T-type grill emblem $20
84-87 GN fenders(GM) $80 each
Non Key locking t-top $90+shipping for the set
86-87 Locking t-tops+keys $200
T-top bags $35
Lock set(all 3 locks with key) $60
Drivers missor $20
Passenger remote mirror $40
Blackout door handles $25 for both
GN Spoiler(GM not after market) all 5 pieces $200
GN tail lights with blackout trim $100
Quarter glass with blackout trim $85
3 piece windshield blackout trim $30
3 piece rear window blackout trim$20
Black wheel well trim $40 each
Turbo plastic wheel wells $80 each
Any other blackout piece e mail me I have them all
GN hood $95-$150
AC lines $45
Fuel pump hanger/sender $50
Turbo gas tank $40
GN sway bars $30 each
windshield wiper assembly $15
Complete heater box $100
Here are some other parts sitting around my shop.
Gray door pull straps $30 a set of 2
Burgandy door pull straps $30 a set
Blue door pull straps $30 a set
Cheap Turbo Crank Std./Std but needs to be turned , has surface rust and light scoring but will definetly cleanup at .010/.010 $200
More Parts for Sale
T-top black plates (the pieces the tops rest on) $50 for both in good condition
Center I beam that the t-tops slide into $50
Intercooled88s said:
CCCI Adapter harness(harness lets you use 86/87 Ignition module with 84/85,plugs into hot air harness $25
With that adapter harness to use the 86/87 coil in the hotair cars, does that have everything needed and all Id have to do is get an 86/87 coil or will I also need other stuff?
I'll take the good stock 86-87 turbo, send me your paypal info.
with S&H to 48310.
interested in the map light, can you shoot me a pic. Mine has the regular round light in the middle up top and its a hard top car. Will it work fine or not thanks Daniel
CTX-SLPR
Everything except the steering box(master, hydro power assist, lines from power assist to Power steering, Power steering pump. I think I have all the lines going right up to the steering box.
my85grandnation
Its just the harness, the car I took it off had drilled holes to mount the 87 module/coil to the 84/85 bracket. Theres only 3 studs on the under side of a 87 module and 4 on the 84 and they are located differently . So to bolt up needs holes dtilled in mounting plaste. They also sell a plate to do this without drilling.
need boost
I sold the map light earlier today, but I believe I have another. I'll send some pictures tomorrow morning , what e mail address should I send to?
You wouldnt happen to have a cruise control cable for an 86/87 would you?
