LARGE Parts List! Come and get it!
jdpolzin
ENGINE, TRANS, ETC PARTS:
1. Stock injectors and Reds chip -----$35
2. Stock Original chip ----------------$20
3. Cam Sensor and Cap --------------$50
4. Oil Slingers -----------------------$5 each
5. Scott Racing Plug Wires (orange) ---------$25 set
6. Passenger Side IC bracket --------$15
7. Drivers side IC Bracket------------$15
8. Used Water pump (known good)---$10
9. 4.1 Balancer (no relucter ring) ----$10
10. Hot Air SFI Intakes -------------$35 each
11. BQ Trans Core (PTS Billet Servo, PTS .570 boost valve) ----$400
12. Rebuilt BRF Trans (stock Rebuild, Brand New, GM clutches) ---$700
13. Edelbrock Valve Covers (Chrome) ----$20
14. 86-87 Upper Intake Plenum ------$25
15. 86-87 Crank Pulley -------------$35
16. Rocker Shafts -------------------$20 each
17. Carb Longtube V6 Headers ---------$50
18. 86-87 Throttle/Cruise/Accelerator Bracket for Intake ----$30
19. Stock Up pipe -------------$20
20. Starter (amlost new) -------------$30
21. MAP Sensors (2 bar) -------------$5 each
22. Inspection Cover (torque converter) -----$20
23. Shift linkage (steering column to Tranny) -----$20
24. PTS Shallow TRANS PAN with pick up tube ----$200
25. Wlaboro 169 pump (almost new) ----------$70
26. Fuel Lines (Tank to frame) --------$20
27. Fan Bracket (Lower elelctric fan) ----$15
28. Engine Oil Dipstick ----------------$20
29. Battery hold down Bracket ---------$10
30. Stock Air Cleaner Lower Bracket ------$10
31. Catalytic Converter Heat Sheilds ------$10
32. Turbo Drainback Tube to block adapter ----$10
33. Power Steering Lines ---------Just ask
34. Knock Sensors (used) ---------------$5
35. NOS Coolant Jug with cap --------------$40
36. Turbo Sheild (lower small one) -----------$15
37. 4.1 Pistons .030 on 2 DOT Rods (NA) -----$30 set
38. EGR Hold down bracket ------------------$5
39. Thermostat Housing hold down clip ---------$5
40. Stock Fuel Pressure Regulators ------------$5
41. Timing Cover (20 bolt) --------------------$50
42. Floor Shifter (4 speed) --------------------$20
ELECTRICAL
1. Grey Third brake light with harness and mounting bracket ---$30
2. Chrome Tail lights (NICE, complete) ------$100 set
3. AutoMeter AutoGauge MONSTER TACH and shift light w/ mounting bracket ---$100
4. Amber Parking Lights (Nice) --------$15 each
5. Cigarette Lighter (original) --------------$10
6. Under hood Light ----------------------$5
7. SFI Body harness (fuseblock to taillight harness) ------$20
8. SFI Tailight Harness -----------------------------$20
9. Dimmer Switch -------------------------$5
10. Defrost Switch ------------------------$10
11. Headlight Switch ----------------------$10
12. Power Lock Relay -------------$10
INTERIOR
1. T Horn Button (outer ring is busted) ------$15
2. Dash/Steering Column Bracket -----------$15
3. Door Chime Box ------------------------$15
4. Rear Sail panels GREY (Uppers, Lowers) -------$15 each
5. Misc Grey Interior plastics -----------------------ASK
6. Grey Pull Straps ------------------------$15 each
7. Sill Plates (Very Nice) -------------------$50 set
BODY, SUSPENSION, MISC
1. Lakewood Drag Shocks (front, 2 sets, almost new) --------$75 set
2. GNX Emblems (Stick On, NEW) --------------$20 each
3. T Type Rim (nice shape) ------------------$35
4. Swaybars (Stock front, Rear) ----------------$20 each
5. 200r4 Crossmember --------------------$50
6. Bumper Shocks (fronts) -----------------$15 each
7. Rear Control Arms (uppers, Lowers) ---------$15 each
8. Headlight Bezel (Black, Passenger Side, Driver) ------$25
9. Hood Latch and bracket ---------------------$15
10. HVAC Box (TURBO, Complete, NICE) -------------$200
11. Bumper Parking Light Bezels (Chrome, NICE) -------$15 each
12. Chrome Front Bumperettes (one has a slight scuff, other is nice) ---$20 set
13. Liscense Plate bracket (Rear, stock) ----$10
14. New Body Side Molding (Black, over half a box from Kirban) -----$30
15. Bumper Shims ---------------$2 each
16. Blackout trim (various) ----------------ASK
17. Lug Nuts (15, GN, stock) ------------$15 all of them
18. Bumper Filler (front grey under grille) ------$15
19. GNX Bushings (New set) ---------------$20
20. 84-86 GN Grille (Chrome is good) --------$75
21. Seatbelt Accuators ------------$10 each
22. Sill Plates (Nice, Body By Fisher stickers intact) ------$50 set
For everyone that has Paypaled already, it's all boxed up and ready to go in the mail in the morning! Thanks guys! ----Jeremy
Jesse, we'll have to plan on another date for me to come up and visit. Get your walls up and I'll come up and device out!
transmission
Where are you located and will you ship to 19090, if so how much
Thanks,
Rems
intrested
I'll take 5. Cigarette Lighter (original) --------------$10
turbo drain and chrome parking light bezels. How is the chrome on them? shipped to 11210. Pay pal fine?
