Buick 400 Trans, 3 spd reverse valve body, racing clutches, hardened stator, trans brake (never used), 4"tail, rear mount plate and stud. Has 100 miles on it. Also includes the 8" G.E.R 4000 Stahl convertor 6 bolt. Does not come with the flex plate mounting bolts. Worked like a dream. Asking $1500.
F.A.S.T computer with communicator cable, Wide band heated O2 sensor 5 wire, Compaq laptop computer and floppy disk as seen in the pictures all included. Asking $600.
Custom built Dual Scroll Turbo, Ball bearing big shaft. Based on indy race car design and to support 950+ h.p. Hits hard and fast, 4" outlet size V-band style. I don't know the size of the wheels or the trimm. No chips or flaws in the wheels. I paid a fortune to have this built and for the price I'm sure John Craig could check it out to get the specifics on it and reseal it resonably. It has been sitting for 7 years and only seen 100 miles on the street. Asking $550.
Precision FMIC excellent shape, includes mounting bolts/spacers, piping, hoses and clamps. The TB hose is for a 90mm. I don't have any other hose to go with it. $675.
Steel Braided Turbo Oil supply and Return lines. Oil supply line has the 2 mounting bolts, the return line does not. $150. shipped.
Applied Techs race gate. Comes with 1 copper gasket and 2 mounting bolts. $125.
Buick Tall valve covers for stage 2 heads. Center mounting holes, 1 has breather filter, the other is missing.
Good shape, I don't have the mounting bolts. $125.
3 Bar MAP sensor with wiring harness as pictured. $100. shipped
Old D.F.I controller box and wiring harness. $30. shipped
Cam sensor, I dont have the cap to this, don't know wtf happend to it. $40. shipped
Aluminum water pump pulley, includes the 4 bolts. $80. shipped
Stock crank pulley, does not have the mounting bolts. $80. shipped
Set of used steel mains from 4.1 stage 2, have some dings in them from losing thrust bearing and throwing a rod out of block. Cross drilled. $120.
Lightly used Delco-Remy starter for the 3.8 engine. $40.
Stock 3" turbo inlet pipe, no holes. Good shape, I don't have any hoses or clamps for this. $25. shipped
9" K&N Cone filter for 4" inlet pipe. Includes clamp. $30. shipped
Moroso Trunk mount battery kit. Cables are NOT included. This was never used. $50. shipped
Brand new never used oil pump rebuild kit for the 3.8 engine. $20. shipped
Injector wiring harness great shape. $65. shipped
Coil Pack mounting plate. $10.
Some items do NOT include shipping cost, I would be willing to meet 1/2 way for transmission delivery.
Pay attention to pictures for details you are looking for please. I have tried to be very thorough on what items include and do not include as well as holding a tape measure to give dimensions.
