mikesvwservice
- Apr 22, 2005
Hi Everyone,
Need some "expert advise" on bigger injectors. All my mods are below with the addition of rebuilt, Champion style flowed heads, Felpro 9441 PTs (w/ARP bolts), Turbo Regal "Big Mouth" air filter kit (8" cone removed), and LT1 Translator (not the +).
RJC Power plate and Lower Shores boost bleeder valve have been removed.
I've blown 3 head gaskets and melted 1 piston in my learning phase. Now I have Scanmaster and Turbo Link vers 3 & 4.
Everything is back together and I will slowly start from 15psi and work my way up (cautiously) in higher boost.
I don't plan to upgrade the cam and these should be all the bolt-ons for my stock block engine. The ECM is stock - no FAST system in my future. I don't plan to track the GN much (hopefully attain 11s or 12s once in awhile) - but want a "street warrior" to spank the occasional Vette or Stang...
So, with that - what do you guys recommend injector size wise (and brand)?
Thanks in advance,
Mike
Thanks in advance,
Mike
