Leak from Rear End
I have the same issue now. Ordering The National 2043 seal. Never did this before, so RTV on outside of seal and on the spline also? Loctite on the big nut? And anything on the 4 bolts to the driveshaft? Thanks in advance
blue Loctite can be applied on all
the bolts and nut
check and confirm case vent is open.
yes a sealant on the spline will prevent oil from coming up the shaft, no need to apply a lot
