turbo buicks
ESADAH!!!
- Jun 13, 2002
the metal fuel line under the regulator that has a flare fitting on it is leaking from under the nut. not the threads, the nut. it leaks through the center of it and drips slowly. i tried to fix the adjustable regulator on there but ended up putting on my old stocker. it leaks very little now if any. are these lines known for leaking and whats the fix?
