Lean at first accel, like a bad accel pump on a holley
Roc87
11 Second V6
#1
Have this over in normal tech section as well. 80# injectors, fresh from a FullThrottle cleaning, a TT6.1 chip... GN seems like it has a carb with a bad Accel pump. Going from a normal cruise which seems lean enough anyways, its going even more lean when you first accelerate. MAF seems fine, TPS is linear, the O2 is new, tried changing the primary FP in the DP set up, tried a different ecm, drained what I thought might be old gas out and filled with fresh gas, fuel pressure rises 1:1 as it should. Nothing has made any difference. I emailed Eric a small file, we'll see what he suggests, but anyone else have any ideas?
