On my stock 86' T-Type as soon as I hit 3rd gear at wot the 02's drop down into the low 700's! This is at 14 lbs of boost. Checked the fuel pressure at wot with fuel pressure set at 40 psi (line off) and it was only 51 psi. Should have been 54 psi. Raised the fuel pressure to 45 psi (line off) and it was still at 51 psi. This is with a brand new Accufab adjustable regulator and a new stock fuel pump, plus a new 02 sensor. I know I need to upgrade the fuel pump but can't do that until I have the gas tank cleaned out because of an issue with rust. My question is this: would a hot wire kit help this problem and should a brand new stock fuel pump be this weak? Forgot to add that it has a new filter too. Thanks, R.B.
