87turbot-type
wo2
- Sep 2, 2007
So I've just started doing some wot test runs in the car to see what bugs I may have and weed them out. After logging a few runs and playing around with fuel pressure and fuel control setting in the chip. Everytime I hit 15psi of boost I start to lean out and it seems as if it must be loosing fuel pressure. (I'm at 10.5:1 and will go as high as 12.8:1 at 20psi) I'm going to borrow a fuel pressure gauge to that I can hang on the windshield and see if my theory is right.
My fuel setup is GS340 fuel pump, Racetronix sending unit with -8an line out, -8an SS front to back, champion intake with rails, 80lbs injectors (75% duty cycle @20psi)
Turbo is 6131DBB with S cover (So not that big of a turbo)
Only thing I haven't done is install the hotwire kit I have, which I will be doing this weekend.
Has anyone else had any issues like this and what did they find the issue to be. I can't see the hotwire kit solving the problem but will see.
Thanks Brandon.
Thanks Brandon.
