You do know that some of the early model GM computers had an "Idle Learn Procedure" they needed to go through whenever the ECM lost battery power, don't you?
Yes - thanks. I have done that multiple times.
I have also now thrown a new O2, MAP, and dropped the TPS to .38.
I have one more thing that looks interesting. In my OTC4000 - there is a parameter "3rd Gr Sw" - it is always "on"
Is there some code in the ECM that detects 3rd gear from the trans and maybe tells the IAC to add air so if you let off the gas on the highway it doesnt slow the car way down like if you hit the brakes. The trans seems operationally fine - all the gears are crisp and the TCC locks and the OTC confirms that. But that "3rd gear sw" is always on - even when in park (which the ECM confirms proper operation of the P/N switch)
A/C request is "no" and I cannot find any power steering request....
If that is the case - is there a way to unplug/remove that switch or is it in the valve body? Maybe someone knows which wire going into the ECM it is and I can cut it to test?
