Sal Lubrano
- Apr 26, 2002
If you have had experience with a 1999 RX 300 could you please give me some help. When I come to a complete stop while turning in either direction the pedal vibrates which is the ABS activating. This is the only time it happens. I have cleaned all the sensors and checked all the reluctor wheels and they are not cracked between the teeth. I have also used a meter to check the resistance of the sensors two front were 1.5 and 1.6 on a 2k scale and the two rear were 1.06. There is NO code. The tires are really close to brand new and poperly infated. In order to drive safely I have pulled the Relay so the ABS does not activate and the problem is gone but I do need to repair the ABS system. Does anyone have any ideas where to look next. . Really don't want to give the dealership the money since I know I can fix it if I knew what the problem was. All help is very welcome.
