Life after 30 psi???
Not Avg 6
With Razor's kit and a 3 bar map, I know it monitors and spray meth progressively up to 30 psi. But what happens after 30 psi?
Same scenario as your stock maf when it hits 255 :)
There are 3.5 bar MAP sensors as well as 5 bar MAP sensors. AEM has them. They are pricey tho. And a few PSI above 30 wont make too much a difference as far as alky amount.
If you have to run past 30.. you may want to look at air flow mods like better heads/cam/exhuast/displacement to make more power at less boost. I have seen a 109 block run 9.50 in the low 20's for boost.
