light stumble when i let off the throttle
turbotrix2004
hey guys i'm new to the turbo buicks so please bare with me. I don't have a scanmaster yet but do have an actron scanner and pulled these numbers at an idle. does anything appear off?
BLM - 128
RPM - 975
ESC COUNTER - 5
IAC POSITION - 9
INTEGRATOR - 128
MAT - 63
SPARK ADVANCE - 34
TPS - 0.43
I don't remember all the mods that were done to the car but here is what i do know
Deka 60lbs injectors
208 comp cam
egr delete
precision turbo dont know specs on it
Is it only when you let off the gas? DFCO (decll fuel cut off) is a function that cuts fuel on decell. Usually only active at higher speeds. Some chips you can turn this feature on or off. Is it possible this it what your experiencing?
What chip are you running?
Remove the chip. The number is on the bottom side. Don't forget to disconnect the orange wire by the battery before removing.
I doubt it's DFCO, no matter what chip is in there, DFCO usually always has a small delay of at least of second and a half to engage.
