turbov6joe
Signal 1 J-12
- May 22, 2002
I'm in the process of installing a line lock (LL) on my TTA but ran into problems with the fittings in the install kit. Seems that the master cylinder (MC) and all it's fiitngs and lines have a rolled flair, and the lines/fittings in the install kit are all inverted flair. I hit a few parts stores yesterday and no one had a rolled flair to invertered flair adapter fitting. Another thing, did you all just remove the short single line from the MC to the distribution block (DB) and splice the LL in between there, or did you go on the outlet side of the DB and put a T in that position?
This is the most trouble I've ever had installing a LL...
