Line Lock Pictures
TKMBUICK
Does anyone have a picture of line lock and what size fitings and pipe you need.
thanks
I'm not sure of the fittings' size. However, if possible, drive your car to the auto parts store and they will know the size of the brake line. Per UNGN (a board member), "be sure to use inverted female to NPT male adapters for the body of the line lock. Otherwise you will have problems". I bought the fittings at Carquest. It took a couple trips to get the right ones. Cotton sells the whole kit with brake line and fittings. Good luck!
Here's mine. I usually install them under the drivers left foot though. The fittings are 3/16" inverted flare and are available from most parts stores. Splice into the lines AFTER the combination valve.
I also use manual brakes. They work GREAT! I also have the brake lines plumbed backwards to increase brake pressure to the rear wheels. Do NOT do this for a daily driver, though. If you need help, PM me your number and I will talk you though it.
Nice "line lok" photos! Where can I get an engine like that ;-)
Do you no what size tubing and fittings to get.
thanks
Go to the link that was posted, go to the second page and read my post with the photos, those are the fittings with part number from Oreillys.
Get those fittings and you'll be fine.
-Adam
