Liquid IC/pump/heat exchanger FOR SALE
Tom Tom Turbo
Turbo Goes Woo Woo
I am going a different route with the car, so this is up for sale.
stock location stretched intercooler with big neck, will fit with the front sway bar in place, as the plates have been professionally welded to allow this ($175 alone). 240 gallon per hour continous duty pump with lines, Earl's Performance heat exchanger, 14x14x2" with -10AN fittings. Comes with everything except the silicone hoses to connect the up pipe to the IC (doesn't come with up pipe, your factory one will work) This also uses the factory mounting brackets.
The IC has been powdercoated black, with the exception of the new plates that were welded in to allow front sway bar use. I can leave it bare, or throw a coat of black paint on them...I won't re-powdercoat it, that's up to you. The pics are before the welded plates, but I can take another pic tonight.
$750 shipped for the package, you couldn't build it for that!!!!
Earl's Cooler from Summit $334
240 GPH pump $129
that means you'd need a stretch big neck IC for $237...not gonna happen! I will not split this up unless I have buyers for everything.
this will flow as much as a big neck, stretched stock location IC, but with the added cooling effect of a liquid IC.
