load leveler air pump weak...
95scpa
Well, my Park Ave air pump was running constantly until it started jamming and blowing fuses.
I figured "air leak" but had to wait until I could afford some down time to repair it.
One of the rear air-over-gas struts were leaking, and I replaced both of them and the compressor was replaced too with a salvage unit.
It worked pretty good for about 2-months and now it doesn't pump the rear all the way up to level, and it was leaking air out of the bleed down hole. (A little nipple valve on the compresor near the top.)
So, it would pump up until it kicked off, and then immediately bleed down, and pump right back up again.
So, I bought a cheap one-way vacuum switch(.. or valve) to allow air in but not out. It seemed to work for a couple of weeks.
But now the compressor runs, good and strong, but the rear goes up very,very slowly and doesn't really reach the cut-off height.
Is there a repair/rebuild kit for the suspension air pump??
Is there reasonably priced reliable aftermarket pumps??
Any help appreciated!...
There are no parts to rebuild your pump. You have to replace the assembly. I show the pump on your 95 also fitting all 1986 to 1995 Lesabre,Bonneville,Olds 88,Olds 98 and 86-93 Deville. For some reason GM changed it on the 96 and newers.
