Available for local pick-up only!!
(3) '109 Turbo blocks:
--(2) are standard bore, never been machined on. $400.00 each
--(1) is a SG1 block that has been machined for a girdle, however the pan rails have been machined down as well. This block can still be used for either a girdle set-up or with just adding two center billet caps. $250.00
(1) N/A '109 block. Just drill and tap a turbo oil return and you're ready to rock 'n roll!! $200.00
(2) BRF transmission cores. Both appear to be oem stock, and are ready to rebuild for your HP needs. $500.00 each
**Please PM me only with all questions/comments/etc.**
K.
K.
