turbov6joe
Signal 1 J-12
- May 22, 2002
During a 1/4 pass, do you lock the converter? If so, at what point is it locked and what kind of MPH do you turn in both the 1/8 and 1/4 mile?
SignUp Now!Originally posted by j13smiley
can you explain to me about locking up the converter? can you even do this with the stock drivetrain or are you running something else?
Originally posted by turbov6joe
Frank,
I also have that boost drop problem that I've been ripping my hair out trying to overcome! For the most part it will drop from 25 psi to ~19 psi when the converter locks in 3rd. Now, if I run it up higher in the rpm's and lock it, it doesn't drop at all and pulls like mad. Eric M. and I have been trying all kinds of different things to make it go away, to no avail. I even switched over to Razors PAC thinking it would fix it. It helped a lot but didn't cure it. At least now it doesn't drop from 25 psi to 10 psi like it did with the SMC kit. What I'm pretty sure it is is that the PI 5 disc doesn't allow for ANY converter slip and drags the motor down SO much it loads up with the alky while it's in a lower RPM fueling table. When I had a D5 it didn't do it, matter of fact, it would spike a few psi on the lock prolly due to some extra RPM. So, untill I finger it out, it looks like I'll be locking the TCC mucho later in the pass....doesn't help with the MPH at all!!
