lockup wiring with switch
87gn505
Does anyone have a wire diagram or how to hook up a switch for the tcc to lockup when I want it to. Any help is apprciated.
IIRC Switch terminal F to ground.
Later AJ
Upper left pin isn't it? I ran a wire down the tunnel to the ash tray and put a swtch in there. Easy to use for me. Also have electric exhaust cutout, fan control, and brake lock there.
Thanks. I went ahed and did that , though I didnt feel the difference. But I am sure it is working the way it is supposed to. Should I flip the switch on when cruising on the freeway?
To test, put the car in 3rd gear, climb a small hill and flip the switch. You should see the RPMs drop and the motor bog a bit.
