UR50SLO
The Reaper
- Jun 12, 2001
Lance or anyone who can help. We are trying to tune this car for the first time. We have a problem with long spool up time and the Wide band won't match what is on the A/R table.
For example: anything above 2500rpm is set at 11.8 a/r
When we data record it says that actual a/r is 12.5
Timing we set at 19.5 anything above 3500 that works fine
Drivability just crusing around is very excellent. good throttle responce after playing with the tps/map adjusments.
Seems like the motor is not quite winding up as fast as normal.
We've only put 16lb boost to it. No popping/weird stuff.. clean passses. Any help with suggestions on how to get the actual to match what's on the a/r table and spool up time would be great!
86 Camaro. 237Cid buick, GN1 heads,.72mmPTE,THDP,Precision's Camshaft(non roller)CAS front mount,ACufb.70throttle body) Art car 3500stall and preped trans(200r) 9"Ford/3:89gears) approx 3200lbs.
  Well.. We ended up going to the track on friday.
 Well.. We ended up going to the track on friday. I'll check the O2 as per Craig voltage before assuming it's the WB sensor.. thanks again guys, Scott~
