looking for 4" bore pistons
norbs
Classic fast, XFI, SPortsman & MS3 programming
Looking for a 4" bore piston set, for 6.3 rod to work with 3.625 or 3.59 crank set up.
Do you know the compression height that you need (22cc revere dome)? Also, what material?
Close, but mine are new Ross for 6.5 rod , 3.59 crank and 4.005 bore.:(
I have not measured the deck height yet, but I;m assuming its 9.530 from the specs TA block has. Heads are 42 CC stage II. Strong enough to support 1100 RWHP.
I'm about to order pistons for my personal car. I can make you any size you want with any CH you want at the same time. Dish dimensions are -22ccs if you want to play with maths.
